I want it louder!!
no problem .like i said i still have my old box thats a inside below the window line for 2 12's if you wanna go that way .also if you want to do a blow thru ,the 15's is the biggest sub that will fit there unless you use a camper shell
i had 2 alts ,a 200 amp and 175 amp adjustable voltage they were 550 alone ,then i had 200 ft of wire at 175 per roll ,my box that has alot of time in it prolly 3-400 in that alone without the ports.then subs amps and batts.i can arrange for you to get some deks batts pretty cheap in ontario .i had 5k in my system easy .but i can be done for less ,if you know what to do and what to get
<s10¢>
San Bernardino, Ca.
<s10¢>
ThxOne
    May 13, 2026
