I want it louder!!
You can get 2 Sundown SA-12 D4's or some DC level 2 D4's and run them @ 1 ohm & It should sound pretty descent running on your current amp... The Sundowns need considerably more space than the level 2's = roughly 2.0 cu ft. per sub for the SA's or 1.25 cu ft. per sub for the level 2's
It's looking like there is gonna be some cvx's for sale. Sundown seems to be a popular choice. Should i do two 12's or four 10's in the sa d4 line?
more cone area with 4 10's the sa's are beast little subs bro my vote on this is 4 sa 10's over 2 sa 12's
[quote name=';8367932]What type of subs should I go with for now with the amp i have at the moment?
Mlstrass' date=' it's like that now until i roll my windows down. With the windows up it sounds like crap.[/quote']
My S10 used to be the same way. Really many pickup trucks gain as much as 4db with a window down.
If you are doing a blow through don't waste it with 10's… At the least I would do 4 12's, 2-4 15's in a 4th order blow through would be sick! I plan on doing 4 15's in a 4th order sometime in the future. If you are doing the blow through make it worth it and go big!!!
<s10¢>
San Bernardino, Ca.
<s10¢>
