I want a single amp setup! Any input?
just go with a multi amp setup. I was going to do a single amp also, but decided to say fuck it and bought 3 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
LMAO. What did your A.D.D. kick in while searching for one?
NINE.5 is 1ohm stable 600w to the sub, bandpass crossovers
4X100@ 4ohm +250@4ohms
4X175@2ohms +450@2ohms
+600@1ohm
those specs are at 12.5v and 0.05 % THD, so you should see a little more than that.
I have been using this amp for about a month and all I can say is that its a nice amp, powerful very adjustable.
NINE.5 is 1ohm stable 600w to the sub, bandpass crossovers4X100@ 4ohm +250@4ohms
+600@1ohm
Already been stated in the thread bro, you can't find them other then used now.
I want to stick with running just a single amp in my next setup.
My setup will consist of a set of 6.5" Massive audio CK6 comps up front and my MKI Brahma(d2) in a 3.5cft enclosure tuned to 35hz. I have the big three done under the hood with just a regular duralast bettery:crap:. I plan on getting a Kinetik HC600 for the back.
Now I'm looking for an amp that can do between 100-150w to the comps, and AT LEAST 600w to the Brahma. Right now I'm looking at the Cadence TXA-6004 . I don't care if it's a 3,4, or 5 channel amp as long as it fits my power needs. What suggestions do you guys have?
You could try one of these.
http://cgi.ebay.com/PIONEER-PRS-D4200F-1200W-4-CHANNEL-AMPLIFIER-AMP-NEW_W0QQitemZ380054600531QQcmdZViewItem?hash=item380054600531&_trkparms=72%3A1071%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
I've install them a few times and they have lots of power are very clean, run cool and are not real big.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
BASS_WARRIOR
Formerly HATCHET_WARRIOR
BASS_WARRIOR
H-town
CrossFired
michigan born
    May 14, 2026
michigan born
    May 14, 2026
