I tought the tuner was an amp..
carlos28355
I know nothing about anything so sorry for my stupidity. My Alpine IVA-D900 was stolen so insurance got me a new stereo JVC KW-M730BT. Im trying to save money and install it myself so im trying to pull back all the crazy cables. I had an old tv antenna that i do not need anymore. Under my seat i thought was my amplifier but it turns out it was a tuner for the IVA-D900. I need to know is this tuner still needed or should i take it out and all cables associated with it? thanks
Sounds like the two Alpine units work together.....unsure if they can work separately. I would remove the tuner and it's wires and install the JVC you got, it'll need a new wiring harness and connecter to plug into the factory one if you don't have one already.
thanks for the replies. I believe i have all the correct wiring. I shall remove the tuner. Maybe the new units have tuners built in now a days and years ago they did not? On crutchfield it doesnt mention anything about an additional tuners. So ill remove all and get back to factory wiring then take it from there i guess...and youre right ill probably need help lol but who can afford good help these days? thanks again!
There is a Michigan MECA Facebook group that is pretty active. They should be able to point you in the right direction.
Im pretty sure that is a Delphi Sirus plug in./Din connector. You may need to contact GM or better Yet, Sirus, and see if they can help you out. I...
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
152
Don’t do it on the ground wire. If you lift the amps main ground and the amp tries to ground through the RCA cable shield, you can damage the head...
14
Check for a blown fuse (or fuses). Referring to the car and not the amp. How do you have the amp wired? Power is directly to battery and ground is...
carlos28355
carlos28355
arizona
carlos28355
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
