Mass Car Audio
Unless he goes with a ebay high output alternator..lolA grand can get the subs amp and a box easy. Alt to ! I doubt
I have a little XS Power D680 I'd sell for $60+shipping. It might be little but it helped me a ton.I found a set of R's with a box for three fifty and a battery for 157 I also seen a 150alt for 200 all on eBay I don't know how good the stuff is but I wanted to get some advice from people that know what they t doing I want to try to get all of the watts to the subs
thats what i would do //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifSo I'm going with a alt from mylow10 two hds300 12's and a Q1-2200 I will be over budget but it will be right so I will be happy
willing to bet his factory alt can put out more amps at idle and last way longer then some cheapo ebay alt.At first, I thought the alternator in your car would do fine, and it might, but I think it is only a 75 amp alternator. If that is the case, it might not do so well. But rather than buy some ridiculously large one, you might look at larger ones made for other models of civics that would do, like this: Honda Civic Del Sol High Output 130Amp Alternator 96 00 Reman | eBay130 amp alternator for 100 bucks made for the del sol of the same year. Again, your alternator may work, I would try to do your build without upgrading it and see how it works out. Should you have issues with voltage, grab one of these and for a hundred bucks you can nearly double your charging capabilities.
Willing to bet you didn't click the link and look at the company selling the product. The price is right because it is a remanufactured alt. made for the same car, but a model that has a need for higher amperage. Often people buy high output alts. when they could just buy one that makes the juice they need that is made for a model of their vehicle that came with a stronger one. The factory alt for his Honda was made by Mitsubishi, as is this alt.. I didn't go looking on ebay for this, I went looking for a more powerful alt. built in the same case and found it, so happened it was being sold on ebay amongst other places.willing to bet his factory alt can put out more amps at idle and last way longer then some cheapo ebay alt.
