x2.Looks fine to me man... scrape away a little paint at the ground maybe.
It's fine. There's essentially a point where too big of a box is pointless. Unless you run IB subs.One more question, as for box i looked up alpine type r's and they recommend them only to a 1.25 cu. - 1.75 cu. per sub in a ported enclosure net. So why isn't my 3.0 cu. ft net good enough for the subs i own? I know they are 4.082 cu ft. but net are 3.0 cu ft.
I figure for the time being i will scrape away some paint and re-ground, but the guy had one p2 15" in a grand am! I do not know why he was hitting so hard. But where can i buy a dmm? Radioshack or something? And should i upgrade the cheap *** wiring they used?I don't see why people always recommend 1/0 gauge and is sure that anything smaller is insufficient. He's only running 1kwrms, I'm sure 4gauge is fine. All you have to do is get a DMM and check whether the subs wired down to 1ohm or not, if its not all you have to do is some re-wiring, easy. Could be possibly you have it wired wrong. Cause you should be hitting harder then a single 15" unless he was in a hatch of some sort or something.
Could be any number of reasons. Was his box sealed or ported? What size? Do you know exactly what power he has?,...etc, etcI figure for the time being i will scrape away some paint and re-ground, but the guy had one p2 15" in a grand am! I do not know why he was hitting so hard. But where can i buy a dmm? Radioshack or something? And should i upgrade the cheap *** wiring they used?
He had the subs on an 800 watt rms amp, in a ported box, he had no idea what the sub was wired to or what the box was tuned to.Could be any number of reasons. Was his box sealed or ported? What size? Do you know exactly what power he has?,...etc, etc
Cabin gain also effects this.
Add a star washer as wellGood ground FTW. You wouldn't realize the difference paint makes until you remove it.
I have a total of 6 runs of speaker wire (left/right midbass, midrange, tweeter) running up my car along with power wire, optical cable, and ai-net cable. I had a bit of noise until I did my last install, during which I took a metal brush and scrubbed down my grounding point. I have all those wires right next to each other in the trunk area and not a single bit of system noise; none- at all.
