I think I dont have enough space. :[ :[ :[
You have plenty of space, my Box (in sig) has outside dimensions of 40 wide x 22.25 tall x 22 deep. Its 8ft^3 tuned to 38hz with (3) 6" aeros, which is right around the volume that would be good for those HDCs, with your dimensions you have space to easily give them more than that.
How many aeros would I need?//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I would say 3 6" aeros would be good, works well w/my box.
more than enough room...you could probably fit two 18s if you tried. 11 cuft is alot of air....especially after displacement
geeezz wow if that space would work for 2 18's i will order the 18's for sure, and will have the box build with aeros. I hope it really does work though.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
what are the hdc18s said to be at? like 6-8 a piece? if you have 10 cubes you could probably run 2 of them...but the fifteens might sound better with a little more room plus they don't displace as much air
Thats the maximum space i could work with, and nvm on the 18's lol.. 15's will do with some nice aeros btw is there any diference from using aeros to just having a normal port made on the box:confused:
You only have ~12 cubes GROSS. After sub and port displacement, you wont have room for 18's. If you can squeeze a couple of inches here and there and use aeros it may be possible though.
Wish I had space for those 18's.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Why did you tune so high? Would you recomend aeros or just a normal port made on the box?
MmatsDude
MmatsDude
Los Angeles CA
pr-festiva
