I PHUCKED up dearly, can someone help me? simple ohm problem.
eb2phkingood
I had this sub sitting in a closet forever:
Rockford Fosgate P212D4 - Sonic Electronix
and then i bought this amp off craigslist for a STEAL of 20$:
http://www.cadencestore.com/ProductCart/pc/viewPrd.asp?idcategory=100&idproduct=260
as you can clearly see though, the sub is dual 4 ohm, and the amp is not made for that. What is the best way to wire this for the time being until i get a proper subwoofer to match this amp? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
the amp is 2 ohm stable in stereo. DO NOT HOOK A 2 OHM LOAD UP BRIDGED!!
wire it 8 ohm series and bridge that , it will see 200 rms that way.
wire it 8 ohm series and bridge that ' date=' it will see 200 rms that way.[/quote']
ok, how do i wire it ohm series and bridge that? do you have a quick link with a picture i could see? please!
Sell it and get better stuff
this is the amp you recommended i buy for the cheap *** project i told you about off ebay. and the sub was the one i told you that was dual 2 but turns out i F'd up and its dual 4 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif((( good thing its for a high school project for my brother and not a car lol
You could also run a coil off each channel I guess
i've had better luck in mono in this situation. say he has a track that basses hard on the left channel , it will only push one coil and that can be nasty especially if its a note thats in phase on one channel and outta phase on the other. it will literally pull the 2 coils in different directions. which will lead to woofer failure. mono will be safer.
eb2phkingood
eb2phkingood
kansas
Bassin Buick
