I need to know ASAP!
If there is enough room between the back of the seat and te slanted side I would mount them there. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I was thinking about mounting the subs closer to the driver side since the port is on the passenger side. Would that work? I want to get SPL out of this setup so what would be best? Also the port will be at the bottom of the passenger side and the subs must be mounted kinda low in the box because of lack of depth further up. Thanks.
Originally posted by F150Matt I was thinking about mounting the subs closer to the driver side since the port is on the passenger side. Would that work? I want to get SPL out of this setup so what would be best? Also the port will be at the bottom of the passenger side and the subs must be mounted kinda low in the box because of lack of depth further up. Thanks.
Yeah that would work. Just make sure there is enough room in front of the sub. So that it doesn't hit anything during excursion. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
F150Matt
F150Matt
Houston, TX
ramos
michigan born
    May 14, 2026
michigan born
    May 14, 2026
