i need some advice
towncarblue
bx
i got a 2008 toyota rav4 and its still under warranty. it comes with a 120A alternator , i replaced the battery with a duralast gold 600cca from autozone. i currently have two re se12 powered by a kicker zx1500.1[150A fuse][subs] and a mbquart discus amp [60A fuse][mids &highs].
i would like to upgrade my subs with some 1000 rms subs [ two RE SX12's]
in order to run a new setup i would need a more powerful amp.
i was looking at a audioque 2200D amp [200A fuse rating]
i did the big3 to my vehicle already
i have no idea if my alt and battery can power this new setup
replacing my alternator is out of the question because it would void my warranty[not too sure if a toyota 140A alternator replacement would void it though , it is a rav4 option]
would a better battery fix my power needs?
what else can i do to power these subs?
a better front battery should help alot, get a good amp that does rated power at lower voltage. the 2200d is great sundown 1500d is nice. u have to wire it up ditch the duralast i had the same batt imo it's one of the best starter batts out there. its not for car audio.
i need battery advice.
ive done some searching and kinetik comes up as a good battery but im in my car alot and i have the engine off but still have my radio on for about 30min-1h , drive for 15min then turn the car off again . i need a battery that will not be killed if it gets drained too much
also the sundown 1500d would not be enough power for two 1000rms subs
the sundown is a good amount more expensive than the audioque and they both got good reviews , what would be the advantage of sundown vs audioque
installing a second battery might be a problem for me .
instead of adding a second can i just replace my main battery with a bigger/better one?
if so what do you suggest?//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
if i replace my main battery with a KINETIK HC3800 or KHC2400 as my starting/ only battery
will that be enough or do i still need to add another battery?
i think im gonna replace my stock battery with a 9A31P
Deka Intimidator AGM Battery.
would that make my 2400W rms system work with my stock alternator or would i still have to get another battery?
towncarblue
towncarblue
bx
towncarblue
vegang
vegang
