i need some advice new amp
NELSON583
ok i like to change my amp i have a pyramid 500rms 2 ch. i like to now if someone now this amp spl by power acoustic
SPL Series I Extreme Power 1600w 2-Channel Amplifier
Full Mosfet Power Supply
PWM Circuitry
Full Selectable Crossover, Hi/Full/Low
3-way Protection Circuit
2 Ohm Stable Stereo
Tri-Mode Capable
Variable low Pass 40Hz-120Hz
Variable Hi Pass 150Hz-1.5KHz
18 dB Bass Boost @ 40 Hz
Frequency Response: 10Hz to 30KHz
S/N Ratio: 97dB
THD: 0.02%
System Distress Indicator
Hi/Low Level Inputs With Floating Ground
4 Ga. Power/Ground Connection
Gold Plated RCA Connectors
Line Output4 Ohm RMS 310 x 2
2 Ohm RMS 370 x 2
Mono RMS 740
Bridged
ok i build a sealed box for 4 sub 10 inches at 1cf. each. my sub. audiobahn aw1051q 300 rms watts. now i have a pyramid 250 rms x 2 the bass sound ok now but i want more power to move my sub . a have friend runing 4 sub. in a sealed box with a power acoustic 2 channel the bass is loud around $200 for now. but i need some advice w/.power acoustic 1600
Ok, so you have 200bux to spend on an amp. Those Audiobahns have dual 4ohm ratings, which means that hooking up four will give you a 2ohm or 8ohm load. I suggest a mono amp, just makes it much eaiser. And the amp this is right in your price range is the JBL 600.1 @ http://www.ikesound.com which will give you 700watts @ 2ohms (they sold out, so try looking around at other places, dont really know off the top of my head). I wouldnt trust Power Acoustic....
EDIT: Also look into US Acoustics @ http://www.thezeb.com they have all the goodies you need for only 37bux more, free shipping, Subsonic Filter, remote gainn. The SSF is used if you want to port your box later. USX also puts out 700ish watts when your car is on (14.9volts)...
NELSON583
NELSON583
FLORIDA
mamey69
BP1Fanatic
BP1Fanatic
