ok i like to change my amp i have a pyramid 500rms 2 ch. i like to now if someone now this amp spl by power acoustic
SPL Series I Extreme Power 1600w 2-Channel Amplifier
Full Mosfet Power Supply
PWM Circuitry
Full Selectable Crossover, Hi/Full/Low
3-way Protection Circuit
2 Ohm Stable Stereo
Tri-Mode Capable
Variable low Pass 40Hz-120Hz
Variable Hi Pass 150Hz-1.5KHz
18 dB Bass Boost @ 40 Hz
Frequency Response: 10Hz to 30KHz
S/N Ratio: 97dB
THD: 0.02%
System Distress Indicator
Hi/Low Level Inputs With Floating Ground
4 Ga. Power/Ground Connection
Gold Plated RCA Connectors
Line Output4 Ohm RMS 310 x 2
2 Ohm RMS 370 x 2
Mono RMS 740
Bridged
PWM Circuitry
2 Ohm Stable Stereo
Tri-Mode Capable
S/N Ratio: 97dB
THD: 0.02%
2 Ohm RMS 370 x 2
Mono RMS 740
Bridged
