I need my Pioneer 880 fixed...!
Try these places Brah
Also have you cleaned off the leads on you faceplate and that spot it connects to. Try it.
the leads? could you get a pic or tell me more? thanks, would really appreciate it. I would like to try it
and if I can't fix it with the leads thing, than I found a place local that will repair it for $125 max, and with 90 day warranty.
On the back of your 880, you'll see some gold metal connects. clean those with an an alcohol pad or something like that. I had an issue with mine that my face wouldn't even come off. When it finally did I cleaned off the connects and have not had that issue since. It solved an issue with the volume on the face not working sometime too. Like if I turned it down or up it would not work. be gentle with them and make sure they aren't bent or anything like that. Worth a shot before calling out for repairs and all that.
sounds good I will try that, maybe rust yur saying? I'll look into it..thanks:veryhapp:
United Radio. /thread
They are the largest authorized repair center for most manufacturers, great place. Shouldn't be much more than $75 unless it's major...
nG
Got any contact info? And I would not think its major, everything but the rca issue works
edit: nvm I found it
da box king
da box king
Portland, MI
da box king
michigan born
    May 14, 2026
michigan born
    May 14, 2026
