I need help
Says the little kid that steals other people's videos and puts them on his channel. Fking retard. Get a real job you little snowflake. Leave car audio to the adults that actually know why you dont fking use 4 inch aeros for high displacement subs like ZV5 15s, fking noob.
Talk about getting a job, you are literally sitting on your fat *** typing on a forum. ******* kids these days thinking they know everything.
You are? Oh perfect. I have Norton but I'm pretty sure the virus is still there. It's one of those hard to get ones. I don't have a different monitor to check...wish I could tho. Almost positive I need a new monitor anyway.,..have had this one for 10 years and I see some words that are squiggly/moving back in forth, sometimes.
sounds like your monitor took LSD //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well I'd rule out the monitor first. if you can't find one to test on, you can connect to your PC from a smartphone or another pc using logmein software and use your phone as a screen to see if the squares are there.
if the problem is not the monitor, it will show up on a remote connection.(I think, I could be mistaken about this one because those services often run really poor basic graphics)
If it's a virus, it sounds like one that messed with system files. I don't really like removing viruses because it's tedious trial and error process. I prefer to wipe windows clean, so, whatever it is, let me know and we'll deal with it if you want.
Also graphic artifacts could mean the graphics chip is overheating, or maybe it just needs new drivers.
Lol the maddest loser ever to visit this forum.
Making new friends again lol. Big mistake putting you on ignore list. Your one of the few people here with a huge range of expertise in everything....like the next TaylorFade. Where is he?!
sounds like your monitor took LSD //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifwell I'd rule out the monitor first. if you can't find one to test on, you can connect to your PC from a smartphone or another pc using logmein software and use your phone as a screen to see if the squares are there.
I'm hoping your right, along with my guess also, about computer monitor. Imma see if my kids' tv's has that special connection for cable cord in back. If not, dam...not to late to add to Chiristmas list lol I can snag one up new/used for like 50 bucks or so on CL.
why not? its more efficient
Because if you want to get loud you want as much port area as you can get and typically rectangular is best to give you that. Also having the port across from the sensor is generally best for the meter.... ie. port behind driver for DB drag metering or port up top for at the kick metering. I gained almost 1.5dB opening my port from 300"^2 to 420" and that's keeping tuning the same and working with less than optimum shape.
Thanks for proving my point. All these retards on here are so 1 track minded.
If you have all the answers why did you come here and ask the question? Use your 4" round ports 6" long and see what happens.
Geometry says that before you get to 1" peak to peak displacement with those woofers you completely unload your port. Good luck!
SubwooferVideos
TX
Boomin_tahoe
