I need a Ported box, what do i do now?
Option-
Buy a dual 12 inch sealed pre fab enclosure for your car, mount a baffle over the second hole to seal it off, just take a round peice of MDF big enough to cover the hole, line the outside edge with silicone and mount the baffle. Spray paint the baffle a color of your choice.
If the box has seperate chambers internally, take a drill with a hole saw attachment and turn the internal divder into swiss cheese so the box is one big chamber.
you now have a large enclosure ready to be ported
For port sizes just ask one of the guys what the width and length the PVC tube needs to be based on the size of the box which will be around 2cft.
Also my last help with this box. If you find a guy named josh99ta, he has done lots of work with ***** Am's he maybe able to help you. He may or may not its worth a shot though. The guys knows ***** am's like you wouldnt believe.
You can find him mostly at forum.soundillusions.net
Look at this box for your car and picture one hole blocked off with the port mounted in it.
Do you guys think by chance there is anything wrong with the sub I was sold? Id really like to believe it was brand new as told, but i can't rule out the possibility that the problem is the sub itself.
well there's always that possibility.
how do i tell if there is a problem with the sub itself? It is measuring like 1.3-1.5 ohms when we tested it, but the guy told me the multi-meter we used is usually off a little bit.
Do you have a home audio reciever you could hook it up too?
Wire it in series so you get a 4ohm load and let it rip on the home stereo.
No, but my friend does. //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif What would that tell me though? It would probably be running at like 200 watts or so if i hooked it up to a reciever. I need to find someone with a 1000 watt amp so i can compare it with mine.
ls1pimp
ls1pimp
NJM
Beat_Dominator
BP1Fanatic
BP1Fanatic
