I need a budget 1000 watt 1 ohm stable mono amp
You will in no way get any where near 1k from that PPI amp. You just paid for a 500rms amp hope that works out for you...
I was thinking about picking one of these up. What makes you say he will not get 1k out of it? Have you personally test the amp?
These factors will affect any amp, not just the PPI. They do almost 122 at 13.8v and over 800 at 2(these take into account effeciency and voltage drop and to some extent box rise).
Granted if you wanted to have 1000 on tap at all times you should go a little bigger.
I placed 4 washers under each mounting tab to get some air underneath(I also have a Stinger scroll fan in place where it has taken the place of my mmats amp at the moment)..I recently put it in, so we will see when it gets hotter, but The scroll fan should keep it quite cool and being raised as I do all my amps.Fans are cheap.
The washers are a good idea thanks. With the fan how do you power it? Do u hook it up to the signal cable?
Sent from my LGLS885 using Tapatalk
Ground to ground block(i use a solid block for grounding,and power to remote (turns on/off with radio)
There are a bunch of great amps on Amazon that will do a solid 1000w
The Belva 2000.1, the vvme inno d1500.1 the shark 2500
All around $100-$150 new and can be wired at .5ohm
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
165
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
119
Fat...Lac
Fat...Lac
Phoenix
tymoto21
    May 18, 2024
    May 16, 2024
