I dont need help. I need a Answer
ok im not beating around the bush because I've tried to figure this thing out but its just not happening for me.
I Have a 2.7cbft Box (Net Volume) I have 3- 10" Pioneer Premier Champion Pro subs inside of it. It is a Common CHamber Box and I am willing to do 1 or 2 ports.
The Round Port Suggestion for the subwoofers are here (IM sure thats single Chamber suggestions)
0.9cbft 3 x 3.5 (inch)
1.2cbft 2 x 2.5 (inch)
0.6cbft 3 x 7 (inch)
Resonance frequency is 34.7hz
Xmax 11mm
But I have a common chamber because im building under a truck seat and it has alot of bumps and grooves.
There's the manual if that helps any. I just want some suggestion on NET port size HxWxD thanks alot
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/TS-W2502D2_InstructionManual1120.pdf
i know im already unregistering i cant take the **** jokes man im askin a simple *** question and people want to joke about the dumb shit. its obvious im fustrated with this shit already he needs to just shut the **** up peace
gl using those 3 10's in such small airspace the pioneer specs are horrid sounding at best //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
just 1 sub in 1.2 ported to their specs sounds horrible and you want to do 3? good luck .
I am speaking from experience too
i had the big 12" 3kw model and it specs were 1.6 iirc and it sounded like shit we did it in 2.5 and it was night and day.
Louderisbetter1
Louderisbetter1
Gainesville Florida
power-fanatic07
