Hypothetical question regarding in-line high-pass filters
GBloes
CarAudio.com Recruit
I accidentally ordered 2 sets of 1st order 300hz in-line high-pass filters. Hypothetically, what would happen if I used 2 capacitors per speaker? Based upon my limited knowledge I’m assuming it’d do absolutely nothing other than eat up power, but I was wondering if there’s any way to use them to create a 2nd order high-pass. Even if it changed the crossover frequency.
these are just fail safes (the speakers can be crossed over =/>200hz using 2nd order) once I get around to putting in the amp and active crossovers, until then I’m using 850hz in-lines. But if I could use 4 1st order 300hz capacitors to get 2nd order that’d be preferable in the short term.
Two caps in series will not produce a second order slope. They can be wired in parallel with each other and then run in series with the load to create a larger value (lower filter point).
It takes a cap in series and a coil shunted across the load to get a second order electrical roll off. Just google some images for basic crossover design and you'll see what I mean.
thanks. I’ll have to research that, might not ever put the information into use but you can never know too much.
GBloes
GBloes
Hamilton
ciaonzo
