HX-2 15s rebuild?
really the only thing you can do is rebuild them back as punch hx2. if u wanted to trying building a franken woofer style thing XXX motors arent the way to go. they are pricy and the design might give u issues
either get you a cheap motor thats bigger then the hx2 and see what you can do or just go out and buy something already. Unfortunately the basket is the cheapest part in the whole thing so yoru pretty much starting out with nothing
nothing is wrong with them at all. BUT the basket is really the cheapest part of the speaker. most people get the motor of one speaker then do a hybrid/frankenwoofer because it can be done and its cheaper then buying a new one. The 06+ XXX motor is a non conventional design so assuming u can find one its going to be expensive to make it work... so if you really want to do that you might as well just buy a XXX
If you want to rebuild the hx2s then hit up team psi...
http://www.fixmyspeaker.com
kwitcherbichin
kwitcherbichin
stantonsburg, nc
kwitcherbichin
    Jun 20, 2026
    Jun 20, 2026
