Death By Bass
WHATS A SUBWOOFER!?!?!?
except that last time I checked, you wanted the mids and tweeters, and woofers as close together as possible, so if you have woofers in the kicks, and tweeters in the pillars, you now have like 3 feet between them...thats why its important to mess around with speaker locations before fabbing. also the midrange does not determine stage height. i believe its ike 5khz or up that will determine the stage height. so to compensate, you can put the tweeters in the pillars and your soundstage height problems are solved //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
not to mention, I thought we were putting the speakers in the kicks so that the signal path was as similar from left to right as possible, ofcourse, this is going to be most evident with the higher frequencies, but if we're putting the tweets in the pillars, then that goes out the window anyway!
