frankiebones
i did 3 huge upgrades this weekend in my 2003 Audi A4: HU, components, and sub:
UPGRADE 1. i had a pair of morel 2-way hybrid ovation 6 components, which is not too shabby at all. i upgraded to morel elate 3-way components: http://www.morelhifi.com/products/mob_3way_elate.html
SPECIFICATIONS FOR COMPONENT SET AS A WHOLE:
Nominal Impedance : 4 Ohm
Power Handling: 200W
Max. Transient Power Handling: 1000W
Sensitivity (2.83V/1M): 89dB
Frequency Response: 20-25000Hz
Crossover Point: 300/3800Hz
Voice Coil Diameter
Woofer: 75mm (3")
Tweeter:28mm (1 1/8")
Midrange: 54mm (2 1/8")
Voice Coil Wire
Woofer: Hexatech Aluminum
Tweeter: Hexatech Aluminum
Midrange: Hexatech Aluminum
Magnet System
Woofer: Hybrid rear vented
Tweeter: Double Neodymium magnet
Midrange: Neodymium rear vented
Mounting Depth
Woofer: 2.4"
Tweeter: 0.8"
Midrange: 1.0"
Morel Elate 6" Woofer [80 Hz - 300 Hz] http://www.morelhifi.com/products/mob_subwoofers_elatesw.html
SPECIFICATIONS: ELATE SW 6" WOOFER
Nominal Impedance: 4 Ohm
Power Handling 160W 180W 200W 200W
Frequency Response: 25-4000Hz
FS: 50Hz
DC Resistance: 3.7 Ohm
Voice Coil Inductance @1kHz: 0.38MH
Magnet System: Hybrid rear vented
HE-Magnetic Gap Height 6mm (0.25")
B-Flux Density 0.8T
BL Product/BXL 6.35
Max. Linear Excursion/Xmax: 8.5mm (±4.25mm)
Suspension Compliance CMS 721
Mechanical Q Factor QES 0.39
Total Q Factor Q/T 0.33
QMS 2.06
Mechanical Resistance RMS 1.03kgS¹
Moving Mass MMS 13.56gr (0.48oz)
Equivalent Car Air Load VAS 14.35L (0.51ft³)
Effective Pison Area SD 119cm² (18.45in²)
Cone Type One-piece formed
Cone Material DPC
Unit Diameter 165mm (6½")
Mounting Depth 61mm (2.37")
Mounting Cutout 141mm (5.55")
Net Weight 1.18kg (2.6lb)
Morel CDM-54 3.7" Midrange [300 Hz - 3.8 kHz]
SPECIFICATIONS CDM-54 MIDRANGE
Nominal Impedance 4 Ohm
Power Handling 100W
Max. Transient Power Handling 300W
Sensitivity (2.83V/1M) 91 dB
Frequency Response 450-7000Hz
FS 300Hz
Voice Coil Diameter 54mm (2 1/8")
Voice Coil Former Aluminum
Voice Coil Wire Hexatech Aluminum
DC Resistance 3.5 Ohm
Magnet System Neodymium rear vented
Dome Type Acuflex Soft Dome
Dome Material Soft dome
Unit Diameter 94mm (3.7")
Mounting Depth 25mm (1")
Mounting Cutout 84mm (3.3")
Net Weight 0.25kg (0.55lb)
Morel MT-23 Tweeter [3.8 kHz - 6.5 kHz]
SPECIFICATIONS MT-23 TWEETER
Nominal Impedance 6 Ohm
Power Handling 130W
Max. Transient Power Handling 350W
Frequency Response 1400-25000Hz
FS 950Hz
Voice Coil Diameter 28mm (1 1/8")
DC Resistance 5.2 Ohm
Magnet System Double magnet Neodymium
Dome Material Silk
Unit Diameter 45mm (1.8")
Mounting Depth 20mm (0.8")
Mounting Cutout 50mm (2")
Net Weight 0.07kg (0.15lb)
UPGRADE 2.
10"ALPINE TYPE-R UPGRADED TO JL 12W6v2. huge sound diff, noticeable but not drastic increase in output, but at least 3 times the SQ relative to the alpine type R in my opinion and in my application.
Free Air Resonance (Fs): 25.0 Hz
Electrical “Q” (Qes): 0.480
Mechanical “Q” (Qms): 7.100
Total Speaker “Q” (Qts): 0.450
Equivalent Compliance (Vas): 2.82 cu. ft. / 79.9 liters
One-Way, Linear Excursion (Xmax)*: 0.65 in. / 16.5 mm
Reference Efficiency (no): 0.250%
Efficiency (1W/1m)**: 85.9 dB SPL
Effective Piston Area (Sd): 77.8 sq. in. / 0.0502 sq. m.
DC Resistance (Re): 6.75 ohm***
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pt): 400W
Driver Displacement: 0.090 cu. ft. / 2.5 liters
Net Weight: 19.4 lbs. / 8.8 kg
http://mobile.jlaudio.com/products_subs.php?series_id=4
UPGRADE 3.
piece of sh*t SQ Alpine CDA-9856 upgraded to a Pioneer DEH-p7800mp.
http://www.pioneerelectronics.com/pna/v3/pg/product/details/0,,2076_310069880_291147601,00.html
sounds unreal in comparison to my old HU, have little to no experience using an equalizer so need to keep playing with it. i got it bc i was obsessed with the BBE processing that the alpine HU had, so i settled on the Pioneer 7800 after reviewing all the audio controls as well as bc of the fact that it also has BBE processing.
Audio Features
Equalizer 16-Band Graphic
Loudness Yes
DSP yes
Listening Position Selector yes
BBE Digital yes
Electronic Balance/Fader yes
Source Level Adjuster (SLA) yes
Crossover Network 3-Way Crossover
High-Pass Crossover (HPF) 50/63/80/100/ 125/160/200Hz, 0/-6/-12dB/Oct.
Subwoofer Crossover (LPF) 50/63/80/100/ 125/160/200Hz, -6/-12/-18dB/Oct.
Subwoofer Direct Control Key
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading)
Preout Voltage & Impedance Hi-Volt (5V), 100 ohm
NOTE: i did the HU install myself, and everything else was held constant so i was able to do a straight up comparison bw the way the same equipment sounded on a diff HU.
then i had the morel 3-way elates done the day after and i wired and mounted the sub that night. any one of these 3 upgrades would be exciting on their own and more than enough to keep me in the car long after i pull in my drive way. all 3 upgrades together is enough to keep me in my car from the time i get home from law school in the PM until its time to go to school for the day in the AM.
only problem is i still have this kicker kx650.4 pushing the morels. i was planning on biamping my 2 way system but with the 3 way system, i am going to stick to the morel mx33.3 passive crossover (http://www.morelhifi.com/products/mob_alignment_cross_mx33.html) especially since the tweeter is 6 ohms and will complicate things even more.
thus, i am now seriously in need of a high end 2 channel that puts out 200+ Watts at 4 ohms per channel. please suggest something if for some reason you are still reading this post after i have rambled on for pages upon pages and included even those specs which are meaningless to me personally.
Voice Coil Diameter
Woofer: 75mm (3")
Voice Coil Wire
Magnet System
Mounting Depth
Woofer: 2.4"
Tweeter: 0.8"
Midrange: 1.0"
FS: 50Hz
B-Flux Density 0.8T
BL Product/BXL 6.35
QMS 2.06
Cone Material DPC
Power Handling 100W
FS 300Hz
Power Handling 130W
FS 950Hz
Dome Material Silk
UPGRADE 2.
UPGRADE 3.
Audio Features
Loudness Yes
DSP yes
BBE Digital yes
