hu/wiring harness connection
  • 4
-=BD=-gEIGH
So I'm gonna install my first head unit today....how do you guys suggest I connect the head unit wires to the wiring harness? Should I solder? crimp? solder and crimp? I know how to solder, but I've never crimped before...any tips/suggestions/guides? Is heatshrinking stuff really necessary? Any info would be greatly appreciated. Thx in advance!
In my opinion either works just fine. solder is the best. but i think the heat shrink isn't needed. just tape it up with some 33+ and your set. never heard of solder and crimping, doesn't sound like a good idea. beside if you going to solder why bother crimping.
thx //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I'll solder it and use electrical tape //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I prefer insulated butt-connectors they look good and if u crimp them good they should never come uncrimped. Heatshrinks are also good but i dislike soldering beacause it can get sharp and cut other wires + its time consuming.
personally i don't see how heat shrink is faster than taping. it may look better but who's going to see the wires anyway.
Your wasting your time if your taping //content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif . Sooner or later the wires will come disconnected and you will have to just do the same thing over and over again some thing that will last like heatshrinking and butt connectors you wont ever have any problems if you crimp right //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif . If you use electrical tape u might as well use wire nuts :p hahahahahahahaha
Well, he's talking about taping after soldering, which isn't bad, per se, but heat shrink is definitely cleaner. Plus, tape tends to unwind, allowing for potential shorting after a while. I guess, since I use heat shrink in my work, I've gotten good at it, it really takes me a lot less time to shrink a wire than to tape it.
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
So is the radio harness spliced direct to the OEM harness? There is no adapter harness?
If the plug matches, you just need to match the wires up. I re-made the harness for my audison amp, and the hardest part was getting the speaker...
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
-=BD=-gEIGH
-=BD=-gEIGH
Los Angeles, CA
defiance
