marleyskater420 5,000+ posts
Banned
my fuse under the hood for the power doesnt stick to each side which causes my music to go on and off,how do i make it stick together?do i just need to buy a new fusy thingy?
it slides in,just doesnt hold to each side.hmm, should just slide into the holder. a pic is worth more.
ok thatll work,would wire in one side work?just some pieces of 4awg?i did that once and it sparked..i dont think i was supposed to but would it work or just blow my fuse?You can either buy a new one or ghetto fix it and just put something like a piece of soder in one side till its tight. I suggest buying a new one because it doesnt cost that much.
but it sparks...is that ok?just put enough in there until it is tight. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
wow...um...yes and no. sparks means theres power..but when you work on electrical stuff and you have to ask if sparks are ok...i would suggest unplugging the battery. (just the negative terminal would suffice)but it sparks...is that ok?
its cool,i fixed it for now.some stuff where it covers wasnt reaching.anyway its all good for now.spark bad, does it keep blowin ur fuse whenever it sparks?
disconnect ur neg connection in ur batt before u do the soldering or anything.
