HU skipping past 46.5db???
no I never had too //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif i have access to the back of the head unit and I held it tight but it still skips and the cd is brand new //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif Also if I roll up the volume it does the same thing 46.5db //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
The tone cuts in and out, this was the 2nd test of the project wired to 1.5ohms to 1 amp, I know theres more to gain with this test setup if I can keep the HU from skipping //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Do you mean when burping a 46Hz tone it skips?
The reason I ask is 46dB or thereabouts is a really low volume and if that's all it takes to make your HU skip then I'd say there's serious problems with it. Like - a sneeze is louder than 46dB //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
A decent fart. A cough. It takes very little noise to accomplish 46 decibels...
lol its buggin the $hit out of me cause I cant fully test the ports at that volume //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Try pulling the HU out and holding it in your hand when you burp. It it still skip, GET ANOTHER HU!
If it does not skip, you are going to have to mount it better. Try foam around the cage.
Newer rangers are bad about not having good mounts, i know a guy doing 43-44's and his HU skips like crazy.BUT....I have a '98 silverado doing 49's and my HU has never skipped (old pioneer deh-p6400, face plate is stating to go out though). It just the mounts in the vehicle usually.
You realize 46dB is not the same as 146dB, right? Or is that just secret SPL competitor language where they leave off the 1 in front?
46db is just shorthand. go to an event and the announcer will probably say "forty-two six db" instead of "one hundred and forty two point six decibels"
all the loud guys know that:boink:
It sounds more like vibrations, but is your voltage dropping below acceptable levels for the HU?
the voltage is fine, I have more voltage in the project than i did in the neon using 2 amps. I'll take it out and hold it to see if it skips then, I do have another deck on hand just in case this one is going, it is 3-4 years old //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
SPL140.2
Team DefJ
SPL140.2
NY
Biker
