Hu noise on ddx-812.
  • 4
sparkplug121988
SWINE FREE!!!
1,259
spokane, wa
I have a kenwood ddx-812 and I have a noise problem. Its not a whine its more like a fuzzy noise! When I turn my hu up and pause the track or whatever im playing you can really hear it. Its just a steady fuzzy noise. I have the big three done all grounds on the amps are good and the rca's are sheilded. What needs to be done? The hu is brand new and so is the amp, rca's, etc.....
turn your SRS setting off or down......//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have the same unit, just tried what you did and nothing happened. My guess is it's in your settings or perhaps a bad ground point.
I had an old ddx-8019 and I got feedback like that when the unit was grounded to the stock harness, but when I gave it a good ground the feedback went away.
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
sparkplug121988
SWINE FREE!!!
sparkplug121988
spokane, wa
sparkplug121988
