Hows this setup look?
Sounds good i would probably go with the bostons over cdt not worth the extra money. Make the box like cardomain not the premade one its probably isnt the best.
Also, im not to good in understanding active vs passive. Will either of those comps be able to be active? also since they are both 2 way I think, that means they are just mid-bass and a tweet right? If it was 3 way it would have a high-mid-low right?
Any pre-built passive set can be run active, just take out the passive crossover and run each midbass/tweeter directly off of an amp...you'd need four channels to do it, and some sort of crossover whether built in to the head unit or an external unit.
Yes.
I don't see any sound deadening on your list. A few rolls is mandatory, IMO...
Well ya ill be sound deadening my doors and trunk. Also, would it be worth that much extra work to make it active instead of passive like you explained how to?
if you were going to go active i would ditch the bostons and make your own components set-up. Do a little searching on active set-ups youll see a lot of different things and go to to http://www.partsexpress.com a bunch of stuff there.
Well list some then :p, im all for cheaper as long as quality stays the same //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
x2 and scratch the Fosgates. that's just me. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
kegan
kegan
soddy daisy TN
kegan
michigan born
    May 14, 2026
michigan born
    May 14, 2026
