How too hook up
Kaboob
LA
I'm a little confused on how exactly to hook up my subs to my amp. I'm going to be getting 2 alpine type r's (dual 4 ohms) and a NiNe.1. Now, what exactly do I use as far as wiring these together. I mean, I know how it has to be wired for the ohm crap, I just don't see how to put the wire in the sub/amp. Where 2 (-)'s have to be connected do I just use a tiny peice of wire or somthing?
You mean in the wiring of the subs? Theres a wiring tutorial on this board, presents all the options available to you.
Im assuming you mean when you connect two terminals on the sub together, and yes, you just use a piece of speaker wire to do that.
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
Kaboob
Kaboob
LA
norcalSRTrida
