Dunno if you read them, but these tips could be helpful on
Amazon's page:
Five Tips for Buying a Heater
Choosing a space heater is a matter of sifting through a bewildering array of types, power ratings, and fuel sources. Let's break it down a little to make the process easier.
What are the different types of space heaters?
Radiant heaters emit infrared radiation that directly warms the objects in front of the heaters (rather than the surrounding air). If you only need heat by a desk or in a small section of a room, a radiant heater is quiet and will use very little power.
Forced-air heaters use a fan to blow air that has been warmed by metal or ceramic heating elements. A forced-air heater is appropriate for quickly heating up a small- to medium-sized room, but can be noisy.
Convection heaters draw cold air from the floor; the air is warmed by heating coils and emitted from the top of the heater. A convection heater is appropriate for quickly heating up a small- to medium-sized room, but also can be noisy.
Radiators work by heating oil enclosed in a reservoir, gradually heating the surrounding air. If heating speed isn't an issue, you might want to opt for a radiator. These are extremely quiet and effective--perfect for bedrooms.
Should I buy an electric or a combustion model?
If you want a heater that will be available in emergencies, or that can heat areas larger than a single room, choose a "combustion" model--one that is powered by a gas or fuel like propane, kerosene, natural gas, or diesel. Which fuel type you choose depends largely on convenience and local availability. For example, diesel would be appropriate for a heater you take with you on long car trips.
How powerful a heater do I need?
Heaters are rated by BTU, which stands for British Thermal Unit (the amount of heat needed to heat one pound of water by 1 degree F). To find out how many BTU you need:
Calculate the volume of the space to be heated by multiplying square footage by height.
Multiply that number by 4 if your insulation is poor, 3 if it's average, or 2 if it's good.
The resulting number is a ballpark figure for how many BTU you'll need.
Do space heaters cost a lot to operate?
As a general rule, electric space heaters are more expensive to use than combustion models. To ensure energy efficiency, a thermostat is a must-have feature for any heater. For radiant heaters, models with a 360 degree heating surface can heat larger spaces. If you need a forced-air heater, models with ceramic elements tend to be more efficient.
Also, my friend brought this one over:
Amazon.com: Mr. Heater F232000 MH9BX Buddy 4,000-9,000-BTU Indoor-Safe Portable Radiant Heater: Home & Garden
Heated up my 3 car garage super toasty in 20 minutes or so, exceptionally effective.
