how to wire up a relay
first check out that site he mentioned.
but if you want a quick "rundown" which I'd advise against //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif....
pin 30 = big power source input
pin 87 = big power source output
pin 87a = untriggered big power source output
pin 86 = trigger power source signal
pin 85 = trigger power source return
30 & 87 are interchangeable, so are 85 & 86.
basically, once the trigger power source signal has been "triggered", big power source input & big power source output are now connected to each other. otherwise big power source input & untriggered big power source output are connected to each other.
if hooking up say 3 amps,
- big power source input = say a 16ga wire from the battery...or a distro block from close by
- big power source output = 3 wires to the remote terminal on the amps
- trigger power source signal = head unit's remote turnon
- trigger power source return = ground
- untriggered big power source output = unused
this might help also.
if you have questions check out www.the12volt.com
yeah i am want'n to run my 3 leds 6inchers crossover and 2 amps of my head unit and someone suggested that i run a relay and i am just wonderin if it will do the job or should i run them another way
couagajl99
couagajl99
Coshocton, OH
couagajl99
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
