how to wire to 2ohm
c0rrupted0ne
so i have an audiopipe 15001d and a 12'' re se dv4. the audiopipe is mono, but it has two inputs for negative, and two for positive. i was gonna wire the re se in parallel (two positive to amp's positive, two negative to amp's negative). However there are two inputs on the amp, so what should i do?
the two outputs are just for running multiple leads.
you don't have to use them both.
If you DO use them both they are parallel to each other, so if you run a lead from each output to each 4 ohm coil the amp would see 2 ohms.
Or you can just use one output and do the parallel wiring at the sub.
c0rrupted0ne
c0rrupted0ne
Sacramento/ San Diego
c0rrupted0ne
