just got a pair of kinetik 1400's question
truckcap22
ky
they both just have the screw in terminals, i want to put one under the hood so i need those battery posts anyone know where i could get those? i'm guessing autozone or lowes walmart didn't have them //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
or can i just get an isolator and keep my redtop under the hood and throw these in the back? i'd really like to do that if possible
If they are new they should come with the posts if not they are 3/8"
well after reserching alot i found no one runs isolators..lol but would i need to fuse between batts? or is that uncalled for?
also, if i'm runnin the red up front, and the two 1400's i'd run 1/0 to the first then connect the two 1400s together then fuse the wire before running to my amp correct?
i wouldnt fuse between the batts in the back..
""also, if i'm runnin the red up front, and the two 1400's i'd run 1/0 to the first then connect the two 1400s together then fuse the wire before running to my amp correct?""
yes. you can do it this way
Fuse after your under-hood battery, Before your first trunk battery and after your last trunk battery.
Something happens to your long run you will be glad you did it that way. As you have juice going in both directions.
pay attention to the last 65 seconds particularly.This is why with a red top you may want to use an isolator
OPTIMA REDTOP WARRANTY INFORMATION
6V, 12V Passenger Vehicle / Light Truck (noncommercial) 36 Months Free Replacement
Commercial 12 Months Free Replacement
*****Abusive service / Deep Cycle Applications / Car Audio- Not covered *****
truckcap22
truckcap22
ky
audiolife
