How to wire this correctly?
Okay so this is my first set of speakers in about 7 years or so and I have never dealt with dual voice coil so just want to make sure I do this all right.. Here's what I have..
2 - Rockford Fosgate R2SD4-12 12" Prime R2 Dual 4 Ohm Shallow Subwoofer with 500 Watt Peak / 250 Watt RMS
And a Sound Storm EV2.1000 1,000-Watt 2-Channel Amp
How do I need to wire the subs to be running at 4 Ohm? Or whatever other ideas as I am going for 4 ohm as that was what I read would be the best setup for these.
All help greatly appreciated.
Would this be the right hookup?
Yes, kudos to you for doing your own research. The Soundstorm amp is clearly labeled for bridge mode. Connect the remaining + and - to the appropriate sides of your speaker terminal input on the amplifier.
IronAnRkst
IronAnRkst
Brunswick, GA
Qbenjamin
michigan born
    May 14, 2026
michigan born
    May 14, 2026
