How to wire subs to amp?
You may have one bad sub if you hook both up as shown,and still having the same issue.You can try ea sub by itself and find which is bad as the amp will go into protect.If you have a DMM,you can check ea subs ohm load on the terminals,anything lower than 3.5 ohms may be an issue with that sub
Both subs work fine by themselves .... Is it possible the amp is not that strong?.... Its a mono amplifier....
By Specs, that amp shouldnt have any issues pushing those subs nicely..Should be POSS to POSS, and Neg to Neg on both subs, and to the amp
EONx93905
EONx93905
Gonzalez
robert420
