How to wire a Xplod ES 1000watt Mono block Parallel
XplodX
I have a Sony Xplod Mobile ES 6001GXD 1000watt Mono Amp and would like to know how to run my 2 subs in parallel. im sure its hellof easy but i dont want to do anythign wrong.
There are 2 sets of positve and negative terminals on this amp for 2 subwoofers
If your amp is like my JBL bp600.1 momo amp, just connect each sub pos. and neg. to the terminals labelled as such. My amp, and apparently yours also, has two sets of speaker terminals, even though it is a mono amp (1 channel). My owner's manual says the extra terminal is just a convenient way to add another sub. The (2)pos. and (2)neg. are combined inside the amp, creating a parallel circuit. Check your owner's manual to be sure. Hope this helps.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
90
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
556
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
903
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
873
XplodX
XplodX
Mendocino,CA
MR_LOWRIDER
    May 18, 2024
    May 16, 2024
