blackbonnie
The Revolution
if your subs are single voice coil 2 ohm you can wire them to 1 ohm or 4 ohm. since your amp is not 1 ohm stable you will have to wire them to 4 ohms, they will end up seeing around 250 a piece if your amp puts out rated power. now if your subs are dual voicecoil 2ohm, then you can wire them to a 2 ohm load and get more power from your amp. these subs will work but depending on your voice coil configuration you might now get the power you want out of them
