how to set RMS for your component set
JoshC
The Taco MASTA
2,913
Houston, tx
I currently just have my gain sitting at like 1-2oclock slightly below 2v(my alpines preouts are 2v). My question is if i wanted to set the gain using a DMM could i just check the wires running to the amp for impedance or is there a different way to figure the ohm so i can calculate a voltage. Thanks
For clarification, the wires run to a crossover which powers my herts mids and DD tweeters. Thats why im wondering if theres a specific way
i would just do it right at the amp terminals.
thats what i meant by wires that run to the amp, so i can just hit it with the DMM there and use that impedance to get my voltage?
Also my mids have a RMS of 100 and my tweeters 80, im giving the crossover 90 right now and they sound great. But my rear 6.5's are on my HU so i have 2 available channels. Would it be better to put my rears on the amp OR give my fonts the full 180rms each. Since my 4ch can do 220x2 @ 4
..but the Eclipse MKii7200 I've got my eye on is better. //content.invisioncic.com/y282845/emoticons/sneaky.gif.7189749b3a3f769e8815b47e8ae87f88.gif
im going to custom fab a copper case for the 9887 and then itll be very similar
couldnt i also just get an external crossover? although a differnt HU would prob be easyer, so i just read threw on the stickie on active vs passive. So basically theres not point in even using HPF on my HU or my amp if you running a passive crossover before your speaker/tweeter? Thats what i got from it, your yall r suggesting that i get a Head unit that has adjustable crossovers built into it for mids and highs then use my 4ch to power each individual speaker correct?
i could also just add the alpine imprint system to my CDA105 and run active that way.
But still havnt answered one question, is there even a point in using the HPF on my HU for my mids/highs or should i turn it off since im running passive
(My high amp is on full pass since i have the HPF set to 80Hz on my HU)
117
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
597
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
715
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
977
JoshC
The Taco MASTA
JoshC
Houston, tx
BnGRacing
    May 18, 2024
    May 16, 2024
