How to run wires from Sub to amp
Just as the question says. THis is my first install and system. I was just wonderin wut is the best way to get the wires from sub to the amp. When in the box?
Is there no wire terminal in the box? All you have is an amp, a plain-jane enclosure that has a sub mounted in it, and nothing else?
drill a hole in the box run the wire through and caulk it up
bolt through the box
speaker terminal if you want
or if its ported run the wire through the port
edit: //content.invisioncic.com/y282845/emoticons/ban.gif.ce8465566702ef9f72e97e794ed1c86a.gif
TheSpeakerMan
Knockin Pics Of da Wall
TheSpeakerMan
Conway, AR
iamamp3pimp
