How to measure if a OEM signal is full range? (trying REW and LOC)
smoka
Drink beer save water
671
Chicago
I have a 15 Durango with no amplifier. I'm trying to see if the tweeter signal is full range (tweeter has a cap on it). My big question is can I run my DSP straight from 2 channels off the OEM headunit or do I need to run all 6 speakers back to a JL FIX82 in order to get a good signal to my DSP?
This is my first time messing with REW. The results are strange. I'm using my laptop with a LOC converter hooked up to the signal right before the pass side tweeter.
Here is my laptop with the REW pink noise generating output looped to the mic input. (I'm assuming this would be the perfect full range signal I'm looking for?)
Here is the signal hooked up to the LOC but the music is paused.
Here is what it looks like with pink noise through the car headunit.
Just for kicks here is rock music from the radio.
My question. Is this signal full range? Is there any need to use a JL Audio Fix 82 to fix the signal before my DSP?
only way to find out if your stock unit is outputting full range is an o-scope
You want to see what it looks like coming from the care head unit with the eq at 0 and flat.
The signal should mirror what is shown on your first graph.
Honestly I would sum all the inputs to the dsp. The more inputs it receives the more it averages out. This should make it easier to EQ back to flat.
One thing alot of people do is boost eq, a little eq boost at conservative levels is ok, but if you are going to push the system to the max you should cut your high points down to match the low points and then add power to make up the overall volume difference
Another thing to consider is that most people ears dont care for a flat signal. That's why eq got popular in the first place to tune the sound to your ears
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
458
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
607
Here is a great little item that will do the bull work of what you want to do. The nice thing is that it doesn’t require a separate remote turn...
smoka
smoka
Chicago
    Apr 28, 2024
    Apr 28, 2024
