how to isntall kill switch quick q
If your using it as a kill switch why not wire it inline with the remote wire so its Normally Closed and then when you throw the switch to the open switch it interrupts the 12V signal that triggers the amps, there turning them off.
The remote wire shouldnt have major amp draw so you can wire it inline, much more amperage then that and you should wire it with a relay.
so that means the kill switch splits the remote wire?
i thought the kill switch needed a constant 12 volt power source?
its fairly simple install but im confused now.
//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
if i do this id shut off both my amps (full range/mono) i just want the kill switch for one of the amps not both.
the only way to make this work is to run two seperate remote wires....one for the highs amp...and one for the bass amp
yeah i already did that
. i split my "main remote" into two.
one for speakers
one for subs.
so now what? i tap into my sub remote wire, right?
like this:
robertoyoung08
robertoyoung08
bay area, ca
robertoyoung08
vegang
vegang
