how to install backup camera correct?
mycar1111
4
ch
how to install backup camera correct?The backup camera installation is very important.
Firstly you need to choose a correct backup camera for your car.there is many kind of car camera in the market right now,but you need to choose one camera which is suitable for your car. There is bumper style,bracket hangle style,or license plate style,or bar style. If you don't want to make a hole to install backup camera at your car,you 'd better install a bracket style or license plate etc.And if you scare the stolen,you'd better choose a bumper style,it is more safe. and also there is car camera with IE LED for night vision or without,if with LED IR,the camera size would be more big,if choose the one without,the car camera you can choose the mini car camera style,when install into the car,it is more hidden,looks more better.
After choose a right camera,and then you need to install the car camera.the different car camera need to install the different position,as for the bracket style camera, you need to install the car camera above the license plate,which along side the license plate lamp position. As for the bumper style camea, you need to install more lower position,usually at the parking sensor level. if it is the license plate backup camera, you need to install at the license plate part.
As for the power you must find out the reverse light power cable in the car,and connect the car camera power to the car reverse light power,because,when turn into the reverse gear,the reverse light would be power on,so the car camera when be powered on to starting working when reverse.
mycar1111
mycar1111
ch
mycar1111
