how to hook up a n64 on a avh4500bt????
  • 5
ballgame
mass
i have a inverter n64 is powered i have a white/red for sound which works with the n64... i have 2 yellows below them for video neither of them work for video. so i have the n64 playing with no video... i have the parking brake by-pass set up with a switch i flick my switch several times i still get no video... any ideas? help? thanks
Put in a dvd and verify the bypass works. You will probably have to tell the deck to turn on the av in and also what type of input you are using. I believe that deck has 2 av input options. Double check which one you have it connected to.
the bypass definitely is working... i am now to the point where im getting a screen if i change the video settings to PAL-m PAL-n as if you have cable on channel 4 but have the tv on channel 3 so its all fuzzy and broken... everything is hooked up correctly... ive stumped 4 local audio places...
im using the yellow/red/white rca wires that come with the 64
goto hidden settings in the deck, turn it off and hold the audio button or source or something, then go through and see if there is anything in there you can change todo with the video input
424
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
ballgame
ballgame
mass
Side Show
