Stormhaven
New to car audio install but I am a very capable mechanic/builder. I recently finished installing as new HU (Pioneer AVH-X8500BHS) in a 2005 Pontiac Grand Prix. This is wired using the GMOS-01 wire harness. Using the preamp outputs connects to an Alpine PDX-F4 4-channel amp. New wiring then connects the new amp to the Alpine Type-R Series 6.5" spr-60c up front and 6x9 Alpine SPR-69 in the rear.
On start up the car does not power the radio up. The light to the amp doesn't turn on either, this I'm assuming is due to the lack of power to the remote wire from the radio. I have checked the fuses, one on the radio itself and the other on the passenger side door fuse box.
What I need is a way to start limiting my possible causes. I have a multimeter but I'm not sure the best way to check to see if wires are hot with out starting to cut them and I really don't want to start hacking up the harnesses.
Also on my GMOS-01 harness I noticed two red 12V wires coming out of the of the wire harness that gets connected to the radio. The factory instructions have no mention of a second red wire. I used the second red wire to connect power my optional MLH adapter for my phone...not sure if this has anything to do with this.
Lastly there are 2 other wires not mentioned in the GMOS-01 instructions. One is solid orange the other is orange/white striped. Something about accessory lighting is written on them but the other half of the harness (radio side) is what the radio's accessory wire splices into. Doubtful this has anything to do with powering up the radio but worth mentioning anything at this point.
If anyone has any ideas to help me recover my car please chime in.
Thanks in advance,
-Hoplessly lost
Thanks in advance,
-Hoplessly lost
