nofriends46 10+ year member
I have a profile elctronic crossover.
Can you hook up a power wire to your distribution
block or you have to run another power wire from the
battery, 16-18guage?
Also the remote, the remote comes from your head unit.
So you only need one remote right, the signal turn on
lead will go to the amps (you wont need a remote wire
to your amps, right or no), or you have to run a
remote to your amps to? Pretty confusing!
Any other suggestions, i'm gonna install 2 amps, one
for sub and 1 for high pass.
What should i set the sub setting and the high pass
setting? My head unit has a crossover, subwoofer
outputs, i just leave the electoronic crossover flat.
ps. if you know a webpage that has a picture, every step, more easier to understand, that would be great
Would it make a different if i install a eletronic
crossover? Thanks!
crossover? Thanks!
