How to hook up 2 amps?
  • 1
Mike6y7m16d
I just got the Kenwood KAC-819 as an additional amp for high's and low's. I already have a Sony Xplod 1502SX for my subs. The RCA plugs on the Kenwood have a ground wire? I am lost here. I need help on how to wire this thing. I also have a Fosgate Capcitor.
Thanks.
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
4
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Mike6y7m16d
Mike6y7m16d
Cincinnati
Mike6y7m16d
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
