link to more info?It's basically upgrading your under hood grounds and battery to alternator wire, Cheapest electrical upgrade you can do.
that sounds like it could be the problem. i did not install my system my brother did buy im getting it redone with a dmmwhat car is it? maybe your gains are set too high causing the amps to clip (pull irregular voltage) thus causing excessive stress on your electrical system. how did you set your gains? with a multimeter I hope
