How to disable door chime?? civic
i get in and out of my car ALOT. and its a hassle to twist the key in and out, I want to keep my dome light functional.
in you ignition harness clip the wire that changes from blue/white to blue/red
now keep in mind it will now be easier to accidentaly lock your key in the ignition as ths is the vehicles keysense wire
Do what the above guy said. You can ziptie/glue the push button down (if you have one)
I'm not so lucky on the other hand.
My grand am has the sensors actually in the door handle, and one of them in my car is stuck open, meaning my lights stay on all the time. I've yet to figure out which door it is lol
As for the buzzer, I tried pulling the fuse for my buzzer/alarm, but the retards tied it in with the brake lights and abs system, so if I pull it, I loose everything. I need to find out where it is, and disable it...
what year?
In sig
Edit:
Actually, my dad check it out, and the two back doors have the push pins (or w/e you call them), but they checked out to be fine.
When changing my front speakers, he looked at the door handles, but we didn't feel it was worth taking the whole handle assembly apart to see what was up, as you couldn't see shit with just the door panel off
In sig
Edit:
you can likely do the same but directechs is being slow i dont feel like waiting for it right now
tintgirl
tintgirl
rockledge, fl
Worlddre
