How to deaden my doors?
UnderFire
Hey, I'm going to be deadening my doors, but the problem is, with my Toyota, there isn't a big fancy panel to cover up all the crap, the "Door panel" in the truck is a single flat piece of cardboard, any Idea how I can deaden this without it looking like the panel is sitting on a piece of tin foil?
Take the panel off, Deaden the inside of your door and the outside metal ( inside the door) get a piece of thin plywood cover on fiberglass resin and cover it to make you a new door panel buy everything from your local hardware store,wood and peal&seal I had great results doing that on my 88 model back many many years ago
Groaned //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Because it's an industrial roofing product not sound deadener //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
That's pretty normal for older pickups. Some much older ones have no trim panels at all. You can apply vibration damper to the interior sheet metal surfaces. If you are going to add a barrier, you'll have t be creative. Photos of the door with the trim panel removed would help in that case.
install deadener on the inside of the door, both walls.. like they said //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I would do min. as possible if its a Leased vehicle or if I do not consider keeping the vehicle after paying it off. I like the Fat Mat 80 mill...
Those are super nice!! I may have to go that route if by chance they don't fit.
19
UnderFire
UnderFire
Dayton, OR, 97114
keep_hope_alive
maylar
    Jun 2, 2024
    Jun 1, 2024
