$500 for front stage in G6.....what to buy??
Jasonc13
Hello all!
Like the title says, I have a budget of $500 to spend on a 4 channel amp and a set of front stage speakers.
I'm not worried about replacing the 6x9's in the trunk lid at this time.
I have 08' Pontiac G6 coupe with the monsoon 3 speaker setup in the doors. The new speakers must fit in the existing mounting areas, as I wont be building out the doors with fiberglass or anything of that nature. 6.5s are the correct size for the mids.
Just as a reference, the front stage will need to match up with a B2k amp pushing 2 12" subs in a custom box in the trunk. Most likely going to be 2 12" Fi Qs as $$ allows. I am currently running 2 Type R 12's.
Should I be shooting for the 125-150rms range with these?
Thanks for your input here fellas //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Here's a pic of the current 3 speaker door setup.View attachment 26527610
Eclipse SC8365's and spend the remainder on deadener.
Those do look like a great set of components, but I also need an amp w/in the $500.
What do you think of either of these amps?
MB Quartz Q4.150 (4x150rms@4ohm) ~ $200
MB Quartz ONYX4.125 (4x125@4ohms) ~ $180
Is it necessary to have 150rms for the front stage? It seems as most of the component sets are more in the 100w range.
What do you think?
Id do this:
SC8365 ELICPSE 6.5" WOOFER 3-WAY COMPONENT SPEAKERS NEW | eBay
ARC AUDIO XXD5080 Class D Car Audio Power Amplifier | eBay
Bridge channels 1 & 2 for the left side and 3 & 4 for the right side. Most 5 channels have an option to run 4 or 5 channel mode. When you get the money do deadener right away. It will make the most difference over adding a 3 way front and amp.
If you want you could drop to nice 2 way front stage, 4 channel, and deadener right away. You could do something like this:
KAR 400.4 ARC AUDIO AMP 4 CH. 400 W. SPEAKER AMPLIFIER | eBay
NEW 2011 DLS R6A 2-Way Refrence 6.5'" Component System | eBay
And spend the remaining $75 on deadener.
Jasonc13
Jasonc13
Charlotte, NC
Epic0318
