How to deaden my doors?
UnderFire
Hey, I'm going to be deadening my doors, but the problem is, with my Toyota, there isn't a big fancy panel to cover up all the crap, the "Door panel" in the truck is a single flat piece of cardboard, any Idea how I can deaden this without it looking like the panel is sitting on a piece of tin foil?
Take the panel off, Deaden the inside of your door and the outside metal ( inside the door) get a piece of thin plywood cover on fiberglass resin and cover it to make you a new door panel buy everything from your local hardware store,wood and peal&seal I had great results doing that on my 88 model back many many years ago
Groaned //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
That's pretty normal for older pickups. Some much older ones have no trim panels at all. You can apply vibration damper to the interior sheet metal surfaces. If you are going to add a barrier, you'll have t be creative. Photos of the door with the trim panel removed would help in that case.
UnderFire
UnderFire
Dayton, OR, 97114
keep_hope_alive
