How to cut 45's with a circular saw?
you making bracing? if you need thin strips that have 45's, work on the master piece, and make cuts with the blade on the angle to begin with. if you need to reverse the angle, flip the board.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
99
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard...
trenthonda1
trenthonda1
Florida
keep_hope_alive
    May 16, 2024
    May 16, 2024
